How to use Tasks
Create your first Task in Reclaim to start defending time for your to-dos directly on your calendar. Tasks help bridge the gap between your always changing to-do list and your availability, so you can make sure you have the time defended to work on your important items before deadlines come up.
5 minute read
How to create a Task
Creating a New Task can be done from within the Reclaim app, as well as across other native integrations.
  1. From anywhere in Reclaim click + New Task in the upper-right corner, or use the keyboard shortcut ‘C’ to pull up the Task creator.
  2. Fill out the total duration, and choose Split Up if it's a larger task and you would like to have it broken into multiple time slots on your calendar. Then choose the minimum and maximum duration of those time slots, and add the Due Date.
  3. Click Create to start scheduling the Task.
  4. You can also schedule a Task (or Habit) directly on the Planner by clicking or dragging anywhere in the future, just as you would in Google or Outlook.
Note: These events will stay locked where you create them.
How to reschedule a Task in the Reclaim Planner
  1. Move the Task: You can simply drag and drop a Task on the Planner to reschedule it.  Once you've manually moved it, it'll lock into place and not auto-reschedule again.
  2. Reschedule: Right-click on the Task and click Snooze. Reclaim will give you future options, and not lock the Task at the rescheduled time.
How to reschedule a Task in your calendar
  1. Move a Task: You can simply drag and drop a Task on your Google or Outlook calendar to reschedule it.
    Once you've manually moved it, it will lock into place and not auto-reschedule again.
  2. Delete a Task: You can also just delete a Task on your native calendar.
    Reclaim will find the next available time for you, and not lock the Task at the rescheduled time.
How to mark a Task complete
In the Reclaim planner
You'll see your tasks listed on the Planner right-hand sidebar, or on the Tasks page in Reclaim. Click the checkmark icon to mark a task as complete.
On your Google Calendar
If you've installed the Reclaim add-on, open it, click on the task, and “Mark Done” with the check mark.
How to log time worked on a Task
In the Reclaim Planner
You'll see your tasks listed on the Planner right-hand sidebar, or on the Tasks page in Reclaim.  You'll see icons / options to “Start” a task, which will start tracking time worked. You can also manually Log Work and add the time spent.
You can also log unscheduled work directly on the Planner by clicking anywhere in the past.
 If you've installed the Reclaim add-on, open it, click on the task, and select Log Work.
