How to enable two-factor authentication (2FA)
1:16
Set up and manage 2FA
Dropbox gives team admins the ability to require two-factor authentication for team members when they're signing in to Dropbox. This is very important to add an additional security layer if they are not going to be using single sign-on.
To get to the setting, you'll go to the admin console, then settings, then two-step verification. By default, this is optional. However, you can set it to required. If you do set this to required, the next time that all of your members would log in using Dropbox credentials, they would be required to set up two-factor authentication. In order to do this, they would do this with their standard two-factor authentication method, which could be Google Authenticator or Duo or whatever they use.
Now for my team, we're going to set it as optional. And then additionally, you can set it up so that specific members are not required to use two-factor authentication; they can be added to this group. Lastly, you can send reminders to any team member that has not set up two-factor authentication. That's simply done by clicking that button.
Ler mais
Outras maneiras de obter ajuda
