How do I set up admin access for others?
As an admin, you don’t have to go it alone! Setting up admin access for others on your team is simple.
7 minute read
With a little help
We all need a little help sometimes, even admins.
Pick a tier, any tier
Dropbox team accounts have several different admin tiers, each with its own set of capabilities and permissions. Before assigning an admin role, consider which tasks that person needs to perform, such as managing members, reviewing activity, adjusting security settings, managing content or billing, accessing reports, or helping monitor team storage. Some tools and settings are only available to certain types of admins, so choose the role that gives each admin the access they need without granting unnecessary permissions.
Tiered admins are available to Dropbox teams on Business Plus, Advanced, or Enterprise plans. Admins on a Standard team all have the same level of permissions (team admin).
Team admin
Team admins have full access to all admin permissions. They can manage members, settings, security, content, reports, and storage management tools across the team.
Only team admins can set other team members as admins or change admin roles. There must always be at least one team admin on a Dropbox team account.
User management admin
User management admins can address most team management tasks, including adding and removing team members, managing groups, and viewing a team’s activity feed. They can also create certain reports, including team storage reports and member data reports.
Support admin
Support admins can help team members with limited tasks, including resetting passwords. Support admins can also address common team requests, like restoring deleted files or helping team members locked out of two-step verification.
With great power comes great responsibility
As an admin, giving another user admin access can be a great help to you. But before you do that, there are a few things to consider.
Dropbox | Admin | Admin Console | Delegate better
Delegate better
Granting admin rights to others will make your life easier, but that doesn’t mean you need to give everyone access to everything. In the admin console on the Members page, you can give admin permissions to anyone you choose and pick which type of admin they’ll be.
Common questions about setting up additional team admins
Got a question about adding admins? We’ve likely got an answer. If you have a question that’s not listed here, check our help center for more answers.
What if I want to remove or adjust someone’s admin permissions?
You can remove admin access from the admin console. Click Members, search for the admin you want to edit, then click More next to their name. From there, you can change their settings and permissions.
Can I customize my own admin tiers or access?
No, you can’t customize either. This means you can’t give a user management admin some of the permissions of a team admin.
Can another admin remove my own admin access?
That depends on their role. A team admin can remove your access, but a support admin can't.
Giving admin access
Follow the simple steps below to learn how to give admin access to your team.
How to add or change an admin
  1. Log in to dropbox.com with your admin credentials.
  2. Click Admin console in the left sidebar.
  3. Click Members.
  4. Click More next to the member you want to make an admin.
  5. Click Make admin.
  6. Select the correct admin permission level in the pop-up window and click Add.
  7. Click Ok.
If a team uses Dropbox Replay, its team admins will automatically be assigned as admins in Replay.
Admins can’t be assigned for Replay alone. To assign a specific team member as a Dropbox Replay admin, they need to be added as a team admin in the admin console.
Learn more about viewing team admins in Replay.
Add a user management admin - Giving admin access
Under the admin console, select the Members tab.
1/3
