How to use Dropbox - a guide to your account
20 minute read
Dropbox is a home for all your work. You can store and share files, collaborate on projects, and bring your best ideas to life—whether you’re working alone or with colleagues and clients.
With Dropbox, all your files are backed up to the cloud and available online. You can save, access, and share your important stuff from anywhere, at any time, on any device.
Let’s get started setting up Dropbox.
How to create a Dropbox account
Create an account on dropbox.com.
Type your name and email address (your email address is the username for your Dropbox account).
Enter a strong, unique password.
Click the box to agree to the Dropbox terms.
Click Sign up.
Find the email address on your Dropbox account
Troubleshoot why Dropbox might say an email address is already in use
How to sign in to your Dropbox account
There are 3 ways to access your new account: on dropbox.com, from the Dropbox desktop app, and with the Dropbox mobile app. Get started by signing in to your account on dropbox.com.
How to sign in to your Dropbox account on dropbox.com
Open a web browser.
Go to www.dropbox.com.
Select one of the following sign-in options:
Click Sign in with Google.
Click Sign in with Apple.
Click Sign in, and enter your email address and password.
Then, install the apps on your computer, tablet, and phone to get the most out of your account.
How to sign in to your Dropbox account using Google Sign-in
How to sign in to your Dropbox account using Sign in with Apple
Having trouble signing in to your Dropbox account?
How to download the Dropbox desktop app
Download the Dropbox desktop app.
Once Dropbox is installed on your computer, you’ll see a Dropbox icon in the taskbar
(Windows) or menu bar (Mac) and a Dropbox folder on your hard drive.You’ll be prompted to sign in with your Dropbox credentials. You should use the same email address and password that you signed in with on dropbox.com (this will be the same for all your devices).
The Dropbox desktop app is available for Linux, Windows, and macOS operating systems. Find out more about using the Dropbox with Windows in S mode or on Linux.
Find more information on Dropbox compatibility with your operating system.
What to do if Dropbox won't install.
How to download the Dropbox mobile app
Download it from dropbox.com/mobile, or your preferred app store.
If you already have the Dropbox mobile app on your phone or tablet, simply sign in with your email and password. You can also sign in using SSO with your Google or Apple account.
How to add a file to your Dropbox account
Once you’ve downloaded the mobile and desktop apps, it’s time to put Dropbox to work by adding your files, pictures, and videos.
Add a file to your account via dropbox.com
Once you’ve signed in at dropbox.com, adding files to your account is as easy as dragging and dropping from your computer’s file system. Or, just follow these steps to upload a file or folder from your computer:
Sign in at www.dropbox.com.
Click All files in the left sidebar.
Navigate to the folder where you’d like to save your file or folder.
Click Upload and select Upload files or Upload folder.
Navigate to the correct file or folder in your computer’s file system.
Click Open.
Add files to Dropbox from your computer
Drag and drop files into the Dropbox folder on your desktop. Or, use the Save As menu option in most applications to save files directly to your Dropbox folder.
Files in your Dropbox folder will automatically sync to dropbox.com, and to the Dropbox desktop or mobile apps on any other devices you’ve connected to your account.
Add a file from your desktop to your Dropbox account
Like with File Explorer (Windows) or Finder (Mac), you can drag and drop into the desktop app:
Drag and drop the file into the Dropbox folder on your hard drive.
Select the Dropbox folder when using the Save As option in most applications.
Like to use Microsoft Office? Dive into the “General” area of “Preferences” and you can make Dropbox a default “Save As” location. Just a little time-saver.
Add a file using the Dropbox mobile app
You can manually upload files, photos and videos to your Dropbox account using the mobile app. The steps you take to manually upload files on your mobile device will vary slightly depending on the type of device you use.
How to upload other types of files or files from your device’s storage and external SD card
Android phone or tablet
- Open the Dropbox mobile app.
- Open the folder where you’d like to save your files.
- Tap "+" (plus).
- Tap Upload files.
- Find the files you want to upload, and tap to select them for upload.
- Tap Upload.
iOS phone or tablet
- Tap "+" (plus).
- Tap Create or Upload File.
- Tap Upload File.
- Tap Browse and find the file you’d like to upload.
- Select the location where you’d like to save the file in your Dropbox account.
- Tap Upload.
How to automatically upload photos from the Dropbox mobile app
You can turn on camera uploads to automatically save photos and videos from a mobile device to Dropbox.
Android:
- Tap the menu button.
- Tap Settings.
- Under Camera uploads, tap Turn on camera uploads.
- Tap Allow.
iOS:
- Tap the account button.
- Tap Camera Uploads.
- Tap Ok to give Dropbox access to your photos and videos.
- Choose what you’d like to back up and whether you’d like to use cell data.
- Tap Back up my photos.
How to back up your computer
You can automatically create a back up of key folders stored on your computer in your Dropbox account. After the initial backup, any changes you make to those folders or their contents will be automatically updated on your computer and your Dropbox folder.
You can access the folders, which are backed up under “Mac” or “PC”, from anywhere you use use Dropbox, such as dropbox.com, the Dropbox mobile app, and the Dropbox folder in File Explorer (Windows) or Finder (Mac).
How to create a folder in Dropbox
Create a folder on dropbox.com
Sign in the dropbox.com.
Click Create.
Click Folder.
Name your folder.
Click Create.
Create a folder on the Dropbox mobile app
Android:
- Open the Dropbox mobile app on your Android device.
- Tap the "+" (plus sign).
- Tap Create new folder.
- Type a name for your folder.
- Click Create.
iOS:
- Open the Dropbox mobile app on your iOS device.
- Tap Create folder.
- Next to Folder name, tap New folder to name your folder.
- Type a name for your folder and tap Done when finished.
- Click Create.
How to share a file or folder from your Dropbox account
Share a file or folder from dropbox.com
Sign in to dropbox.com.
Hover over the item you’d like to share.
Click the Share icon that appears.
Type the email or name of the person, people, or group you’d like to share with.
Select Can edit or Can view from the dropdown menu.
Click Settings to customize who has access or disable downloads. You can require a password and set an expiry date too.
Click Share file or Share folder. Recipients will receive an email invitation to the content you shared.
You can also click Copy link (If a link hasn't been created yet, click Create and copy link).
The link will be copied to your clipboard. You can then paste it into an email, chat, or other message.
Share a file or folder from the Dropbox folder from the Dropbox desktop app
Click Share.
Type the Email, name, or group of the person (or people) you’d like to share with.
Click Share. They’ll receive an email with a link to the file or folder.
Share a file or folder using the Dropbox mobile app
Navigate to the file or folder you want to share.
Tap "…" (ellipsis).
Tap Share.
Tap Create a link.
If a link was already created for this content, tap Share link next to Anyone with the link can view.
Select the way you'd like to share the link from the options Can edit or Can view. Either option will allow them to comment.
How to scan documents and upload them straight to Dropbox from the mobile app
Easily upload, organize, and share your scans with the Dropbox doc scanner. You can even search for text within your scans thanks to optical character recognition (OCR).
Follow these steps to scan and save a doc from your phone:
Open the Dropbox mobile app on your Android or iOS device.
Tap "+" (plus).
Choose Scan Document (on Android devices, you’ll need to select Allow when prompted).
Take a picture of content you want to transform into a document. You can also select an existing image from the iOS Camera Roll, or on Android, tap the photos icon.
Dropbox automation options
How to create an automated folder
To create an automated folder:
Click Create in the upper-left.
Click Automated folder.
Name the folder and select an automation option.
Options provided will be Files added to a folder are saved as PDFs, Files added to a folder are unzipped, Files added to a folder are tagged*, Files added to a folder are saved as images, Files added to a folder are saved as videos, and Files saved to a folder are sorted based on category.
Follow the prompt(s), then click Create.
*Only available to users on Dropbox Professional, Standard, Advanced, and Enterprise plans
How to add automation to an existing folder
To add automation to a folder:
Hover over the folder and click“…” (ellipsis).
Click Add automation.
Select the automation option and click Next.
Follow the prompt(s), then click Add.
Note: You must have editing abilities for a folder to add, edit, or delete automations.
How to share an automated folder
Automated folders can be shared the same as any other folder. The folder automation will remain for anyone the folder is shared with. Once an automated folder has been shared with someone, they will see notation that the folder is automated as well as which automation option was selected.
Get more out of your Dropbox account
Learn how to set up your account, share the way you want, and discover more ways Dropbox can help.
