Get started with Dropbox and ChatGPT
Learn how to bring Dropbox files into ChatGPT, use them as context for your work, and check the results against your source content.
10 minute read
You’re preparing for a project review and need to quickly get up to speed. The latest project brief is already stored in Dropbox, and you want to pull out the key information you’ll need for the meeting.
The information you need may already be in the files you use every day. But using that context in ChatGPT can mean stopping what you’re doing to find a file, download it, and upload it again.
In this guide, you’ll learn how to bring a Dropbox file into a ChatGPT conversation, use it to prepare for your project review, and check the result against the original source before you use it.
What can you do with Dropbox in Chat GPT
When Dropbox is connected to ChatGPT, you can bring Dropbox files directly into your conversation and use their content as context for the task you’re working on. This means you can work from the files you already keep in Dropbox without downloading and uploading them again.
Dropbox is available through ChatGPT’s file experience, where you can find, add, and preview Dropbox files. Once a file is part of your conversation, you can:
Understand your content: Ask questions about a Dropbox file, summarize key information, or pull out the details you need for a meeting.
Create a first draft: Use a brief, report, or other source document as context to create new content.
Work across sources: Bring related Dropbox files into the same conversation to compare information, identify differences, or bring important details together.
As you work, you can continue asking questions and refining the result without adding the same Dropbox files again.
The Dropbox plugin lets you take supported actions in Dropbox, such as saving new content. In this guide, you’ll use ChatGPT’s file experience to find and work with your Dropbox files. If you want to save your result back to Dropbox, you’ll use the Dropbox plugin.
Connect Dropbox to ChatGPT
Before you can use a Dropbox file in a ChatGPT conversation, connect your Dropbox account to ChatGPT.
You’ll need:
A Dropbox account.
A ChatGPT account.
Permission to access the Dropbox files you want to use.
Access to Dropbox in ChatGPT.
Note: If you use a managed ChatGPT workspace or Dropbox team account, your admin may control whether you can connect Dropbox.
Connect your account
To connect your account:
Open ChatGPT.
Select Plugins in the left sidebar.
Select Dropbox.
Select Install plugin.
Select Sign in with Dropbox.
Sign in to your Dropbox account.
Note: If you have paired Dropbox accounts, choose the account you want to connect. If you've already connected Dropbox to ChatGPT, you don't need to connect it again.
Your files and permissions
When you connect Dropbox to ChatGPT, ChatGPT can access the Dropbox content you already have permission to access. If you’re part of a Dropbox team, this doesn’t give you access to other team content that hasn’t been shared with you.
Your original files stay in Dropbox. When you add a Dropbox file to a ChatGPT conversation, ChatGPT retrieves content from that file.
Your existing sharing settings, team policies, and admin controls still apply. Content you add to ChatGPT is handled according to your ChatGPT plan, workspace settings, and data controls.
Work habit
Before connecting a work account, check your organization’s guidance for using Dropbox content with AI tools. This can help you understand which work files you can use before you start.
Add a Dropbox file to your conversation
Your project brief has the background you need for the review. Instead of downloading it from Dropbox and uploading it to ChatGPT, you can find the file and bring it directly into your conversation.
Find your project brief
Dropbox is available across ChatGPT’s file experience, so you can bring in a file when you need it without leaving your conversation.
Depending on where you’re working in ChatGPT, you can:
Browse your recent Dropbox files.
Search Dropbox for a specific file.
@mention or attach a Dropbox file to a prompt.
Find Dropbox files in your Library.
Example
For the project review scenario, you could find the latest project brief in Dropbox and add it to your ChatGPT conversation. Once added, ChatGPT can use the file as context for the task you’re working on.
Preview your source file
Before working with the project brief, open the Dropbox preview beside the conversation. This lets you check the source while you continue working in ChatGPT.
Check that:
It’s the correct project brief.
It’s the version you want to use.
It contains the information you need for the review.
Work habit
Check your source before you start. Make sure you’re working from the right Dropbox file and version before using its content in ChatGPT.
Prepare for a project review
Once you’ve added your project brief, ChatGPT can use its content as context to help you prepare. A clear prompt can help you focus on the information that matters, such as project goals, key decisions, important dates, and anything that still needs attention.
Use your project brief as context
In our project review scenario, the project brief can provide the context ChatGPT needs to help you prepare for the meeting.
Copy and adapt this prompt:
Create a project review brief for an upcoming meeting, using only the Dropbox project brief added to this conversation.Include:
1. The project goal.
2. Key dates and milestones.
3. Decisions already made.
4. Open questions.
5. Named owners.
6. Next steps.Add the source file name beside each date, decision, owner, and next step. Keep names and dates exactly as written.
If information is missing, mark it as “Not stated.” Do not guess.
Why this prompt works
A useful prompt gives ChatGPT clear guidance about what you need and how it should use your source.
Goal: What you want to accomplish.
Context: Which information ChatGPT should work from.
Output: What the response should include and how it should be organized.
Boundaries: What ChatGPT should preserve, check, or avoid when creating the response.
Refine your result
Your first prompt doesn’t need to cover everything. You can continue the conversation and ask ChatGPT to focus, reorganize, or clarify the information based on what you need.
For example:
Put the most important decisions first.
Turn the next steps into an action list.
Highlight questions that still need an answer.
Make the summary easier to scan during the meeting.
Keep the summary to one page.
ChatGPT can continue working from the Dropbox file already added to the conversation as you refine the result.
Work habit
Build on the same conversation. When you want to refine a result or explore the source further, continue in the same conversation so you can build on the Dropbox file and context you’ve already provided.
Review and use your result
ChatGPT can help you work through the information in your Dropbox files, but its response should be treated as a starting point. Before using the result, check important details against the original source.
Check the response against your source
In our project review scenario, keep the project brief open beside the conversation while you review ChatGPT’s response.
Check that:
Names, dates, and milestones match the project brief.
Decisions and next steps are supported by the source.
Open questions aren’t presented as confirmed information.
Missing or conflicting information is clearly identified.
The response doesn’t include information that isn’t supported by the source.
If something doesn’t look right, ask ChatGPT to check the response again.
Check the project review brief against the Dropbox project brief added to this conversation.Check that:
1. Names, dates, and milestones match the source.
2. Decisions and next steps are supported by the source.
3. Open questions aren’t presented as confirmed information.
4. Missing information is marked as “Not stated.”Correct anything that doesn’t match the source and remove information that isn’t supported by it. Do not guess or add assumptions.
Review the revised response against your project brief before you use it.
Work habit
Check the details that matter most. Pay particular attention to information that could affect a decision or next step, such as dates, owners, requirements, and confirmed decisions.
Use your checked result
Once you’ve checked the response, you can use it to move your project review forward. For example, turn it into talking points for the meeting, identify questions that still need an answer, or use the next steps to plan follow-up actions.
Save your work to Dropbox
If you want to keep the final brief with your other project files, use the Dropbox plugin to save it to Dropbox.
Enter @Dropbox in the prompt and select the Dropbox plugin.
Enter your request.
Review the proposed action.
Confirm the action if prompted.
Open the saved file in Dropbox and check its name and location.
@Dropbox Save the final project review brief to the [project folder name] folder.
Name the file [project name] project review brief.
Create it as a new file and keep the original source files unchanged.
Note:
Saving the brief creates a new file in Dropbox. It doesn’t replace the original files used as sources.
Try it yourself
Now it’s your turn. Use what you’ve learned with Dropbox files from one of your own project.
Work with multiple sources
So far, you’ve seen how one Dropbox file can provide context for a task in ChatGPT. When your work depends on information from different sources, you can bring multiple related Dropbox files into the same conversation.
For example, you could:
Compare a project brief with the latest stakeholder feedback.
Compare two versions of a document to understand what changed.
Bring together meeting notes and a project plan to identify decisions and next steps.
Use a brief and supporting research to prepare for a meeting.
Adjust the prompt for your task
Tell ChatGPT which files to use, what you want to accomplish, and what information matters.
Compare these Dropbox files and help me prepare for [task].Focus on:
1. [information you need].Highlight important differences or conflicting information, and identify anything that is missing.
If the files don’t provide the information, don’t guess.
Check before you use it
Review the result against the original Dropbox files. Check that important details are supported by the right source and that any differences or conflicting information are represented accurately.
Keep your work connected
By bringing Dropbox files directly into ChatGPT, you can work from the content you already use without downloading and uploading files each time you need context.
Whether you’re preparing for a meeting, comparing feedback, or creating a first draft, you can bring the relevant Dropbox content into your conversation, work from your sources, and check the result against the original files before moving your work forward.
