Where and how do I save my stuff?
Dropbox is a great place to safely share and store your content, whether you’re using the desktop app, dropbox.com, or the mobile app.
10 minute read
You can use Dropbox to save, organize, and update your stuff
Dropbox has the tools to help you organize and seamlessly update all your stuff.
Learn more
You can easily save and sync your files to Dropbox using all your devices.
Watch our quick video tutorial to help with uploading and downloading files.
Saving files on dropbox.com
One of the easiest ways to upload files to Dropbox is with dropbox.com.
Simply log in to dropbox.com, then drag and drop files from your computer. Or, if you prefer, you can select Upload or drop files to choose a file.
Note: There’s a 350 GB file size limit when uploading through dropbox.com. If you have a bigger file, use the Dropbox desktop app instead.
Working offline
On a flight? Or maybe your internet is down? Don’t worry, any edits you make to a file will automatically sync to Dropbox the next time you're back online. You can also make files available or folders available for offline viewing on your mobile device. Dropbox lets you work anywhere, anytime, without missing a beat.
Read our troubleshooting guide if you’re experiencing problems saving and syncing your Dropbox files to your computer.
Upload a file on dropbox.com
To upload a file on the web, simply select the Upload files button. Then, choose the file you want to upload. Once the green check mark appears, you’ll be able to see the file on your computer or mobile device.
