How to use Smart Meetings
5 分読むのにかかります
With Smart Meetings, you can put all of your recurring meetings on auto-pilot. Smart Meetings automatically find the best time for two or more people to meet across everyone’s busy schedules. Create a Smart Meeting to automate a recurring meeting.
Learn more about Smart Meetings
How to create your first Smart Meeting
  1. Click Smart Meetings in the left sidebar.
  2. Click + New Smart Meeting in the upper right.
  3. Fill out the scheduling rules requested in each field (Frequency, Duration, and Ideal Time).
  4. Click Save.
Pro tip:  Smart Meetings will automatically schedule according to the organizer’s priority setting and you and your attendees' mutual availability (across timezones, if applicable). The attendee doesn't have to be a Reclaim user, but you do need to have at least free/busy visibility to their calendar, for example a coworker.
  • If an event gets booked over the Smart Meeting, Reclaim will automatically reschedule it to the next best available time for everyone.
  • By default Smart Meetings are locked at the start of each working day. To change this:
    1. Go to Settings.
    2. Click Scheduling.
    3. Click Auto-lock to lock Smart Meeting events at the start of the week.
How to replace an existing recurring meeting with a Smart Meeting
  1. You will need to delete the recurring event you own from your calendar, and replace it with a new Smart Meeting.
  2. Follow the same steps as above to create a + New Smart Meeting, add an attendee (for example, a direct report for a 1:1), and fill out your preferred scheduling details.
Once saved, Reclaim will send a one-time meeting invitation to the attendee, and start auto-scheduling the meeting.
How to reschedule a Smart Meeting in the Reclaim Planner
Right-click the Smart Meeting you created. You’ll see two options:
  • Click Reschedule to change the meeting for another time or day.
  • Click Skip to skip that meeting instance altogether.
How to reschedule a Smart Meeting in your calendar
Go to the Smart Meeting you created, and  RSVP “No.” Reclaim will find another day for this Smart Meeting.
How to lock a Smart Meeting so it doesn't move again
Locking from the Reclaim Planner
  1. Right-click the Smart Meeting you created and click Lock. Reclaim will no longer move this instance of the meeting.
  2. Click and drag the Smart meeting to a new time. This will ‘Lock’ the meeting and Reclaim won't reschedule it again (you’ll see a Lock emoji).
Locking from your calendar
  1.  Go to the Smart Meeting you created, and  RSVP “No.” Reclaim will find another day for this Smart Meeting.
