Advanced admin features in Dropbox Sign
Configure advanced Dropbox Sign features to manage document retention, automate storage, and support your organization's long-term governance strategy.
5 分読むのにかかります
Your documents have been signed, completed, and stored. But what happens next? How long should they stay in Dropbox Sign? Where should they be backed up? And what happens when it's time to remove them?
At some point, every organization needs a plan for managing completed documents over time.
In this module, you'll explore the tools Dropbox Sign provides to help you back up documents, manage retention requirements, and control what happens to completed documents after the signing process ends.
Team cloud syncing
Team cloud syncing automatically backs up Dropbox Sign documents to a connected cloud storage provider.
This helps organizations maintain copies of completed documents outside of Dropbox Sign and can support retention, governance, and business continuity requirements.
Note
Team cloud syncing is available to organizations on Premium plans.
Supported storage providers
Organizations can connect Dropbox Sign to:
  • Dropbox
  • Google Drive
  • OneDrive
  • Box
Dropbox Sign | Admin console syncing and sharing
Once configured, completed requests are automatically synchronized to the selected storage location.
How team cloud syncing works
Dropbox Sign organizes synchronized documents automatically.
Depending on your account configuration, documents may be organized by:
  • Team
  • Document status
This helps admins locate and manage archived documents more efficiently.
Note
Team Cloud Syncing runs automatically for completed requests, so there's no need to manually sync documents after they're signed.
Once a document has been synced, a copy is stored in your selected cloud storage location. This means that even if the document is later deleted from Dropbox Sign, the synced copy remains available in Dropbox, Google Drive, OneDrive, or Box.
Common use cases
Organizations often use Team Cloud Syncing to:
  • Maintain document backups
  • Support retention requirements
  • Centralize document storage
  • Prepare for automated deletion policies
Ready to create a central home for your team's completed documents? See Team level document syncing and storage with Dropbox Sign for setup instructions and storage integration options.
Document retention and deletion
Organizations may choose to remove completed documents from Dropbox Sign after a certain period of time.
Dropbox Sign provides two deletion options:
  • One-time delete
  • Ongoing delete
Note
Deletion settings can only be configured by an admin and apply across the entire organization. Before enabling a deletion policy, make sure it aligns with your organization's document retention requirements and any guidance provided by your legal or compliance teams.
One-time delete
One-time delete allows admins to remove all currently completed documents from Dropbox Sign.
This option is useful when:
  • Implementing a new retention policy
  • Removing historical data
  • Preparing for a migration or storage strategy change
Note
The recovery period provides a short window to reverse a deletion if documents were removed by mistake. Once that period expires, the documents can no longer be recovered.
Before running a one-time delete, make sure the action aligns with your organization's retention requirements and that any required reports or backups have been completed.
Ongoing delete
Ongoing delete automatically removes completed documents after a defined retention period.
This allows organizations to maintain a consistent document retention strategy without requiring manual intervention.
Common use cases
Organizations may implement ongoing deletion when:
  • Internal policies limit document retention.
  • Compliance requirements require document removal.
  • Documents are archived elsewhere through Team Cloud Syncing.
Note
Ongoing delete only applies to completed documents where all required signatures have been collected. Requests that are still in progress, such as those in Sent or Viewed status, aren't affected by the deletion policy.
Understanding the impact of deletion
Deleting documents affects more than storage.
It also impacts:
  • Document availability
  • Historical access
  • Reporting data
Note
Once documents are permanently deleted:
  • They cannot be recovered.
  • Associated reporting data is no longer available.
Before implementing deletion policies, confirm that any required reporting information has been generated and exported.
Before deleting documents
Consider the following checklist:
  • Generate any required reports.
  • Export compliance or audit data.
  • Confirm document retention requirements.
  • Verify that backup processes are in place.
  • Communicate policy changes to stakeholders.
Best Practice
Enable Team Cloud Syncing before implementing deletion policies
If your organization plans to use ongoing delete, the order matters. Team cloud syncing should be enabled and working before deletion starts, so completed documents are backed up before they’re removed from Dropbox Sign.
A simple sequence to follow:
  1. Agree your retention policy with your legal or compliance team.
  2. Enable Team Cloud Syncing.
  3. Confirm completed documents are appearing in your chosen storage location.
  4. Generate any reports you may need.
  5. Configure your deletion policy.
This helps you move forward with confidence, knowing your documents are backed up and your reporting is in order.
Your Dropbox Sign account is now set up to support your organization, from onboarding new users and securing access to managing documents throughout their lifecycle.
To see how all of these settings come together in everyday work, explore Dropbox Sign for Team Members, where you'll follow the document journey from the sender's perspective and learn the features your users rely on every day.
